mxmantater746
hi all
i have 1997 vmax 600 xtc. the nitrogen in the rear shock is empty. i don't see any residue from a blown oil seal or anything. the cap from the shraeder valve was missing and it was full of debris so i'm guessing it got dis-charged. any idea of the nitrogen PSI for this sled. thanks in advance for any advice.
My cousin just recharged my shock (same one as yours) and put in 200 lbs. He said that was the spec for fox shocks and said that these ones were basically the same design so it should be the same. Seems to work alright.
braindead1684
200 for my XT is what i was told I presume the 97 would be the same.
mxmantater746
thanks guys. that helps alot
mxmantater746
i do have one more question that i forgot about. what does the slotted front mount do?
gild
fra
Tech pages said 284 lbs for the XTC Kayaba. Slotted shock mount is the full rate adjuster 3 setting for shock tension
mxmantater746
cool. thank you sir
