Limiter strap adjustments
sdahm
Wisconsin
I've got like a half to three quarters of an inch left worth of bolt to adjust my limiter strap. I just want to let it all the way down for a few rounds in my field to pop some wheelies and get some pics. I can get one ski off the ground without even trying, but not quite both at the same time. Will that small of an amount make a difference?
Soften you rear shock spring and stiffen your center spring.Set your transfer rods to full transfer.
Id be a little concerned with the track catching the rail tips if you let the limiters out all the way.
