john7459 New member Joined Sep 16, 2008 Messages 135 Age 44 Location Colgan, Ontario Dec 15, 2009 #1 How much tension should it take to rotate the secondary? (and by rotate I mean separate the two plates). If I grab the closest side plate and push / rotate down it seems to open up pretty easily. Is that called deflection? can I measure it? Thanks Attachments clutch.jpg 27 KB · Views: 1
T Turk TY TECH ADVISER Joined May 2, 2003 Messages 2,806 Dec 15, 2009 #2 Use a fish scale to measure how many pounds of force is needed before you can open the shives. A newer srx should be about 16ish pounds. A 4 stroke secondary is close to 30 pounds.
john7459 New member Joined Sep 16, 2008 Messages 135 Age 44 Location Colgan, Ontario Dec 15, 2009 #3 Thanks
