secondary clutch
john7459
Colgan, Ontario
How much tension should it take to rotate the secondary? (and by rotate I mean separate the two plates).
If I grab the closest side plate and push / rotate down it seems to open up pretty easily. Is that called deflection?
can I measure it?
Use a fish scale to measure how many pounds of force is needed before you can open the shives. A newer srx should be about 16ish pounds. A 4 stroke secondary is close to 30 pounds.
