Running board grip
meat12
Central WI
What are you guys using for it. My running boards are pretty slick and I would like a bit more traction. Wondering what others are using. Any advice would be much appreciated.
Meat
Fett Brothers Surefoot III. You won't be disappointed. I think available either directly from fettbrosperformance.com as part YF100P or at Dennis Kirk as part 49-0758. $62
i plan on doing bethevipers mod on mine too, but i still want to use the surefoots after, i'm going to use the cat siderails so probably the cat surefoots would work with some modification
X2 Thats what I am running and I love them!!!!!
i saw a set of rox inserts just recently, not sure if it was on here or ebay though, i myself found a set of running boards that sombody for some reason cut off a nytro on ebay and integrated them into my running boards, i see them on ebay once in a while too. good luck
If i feel ambitious i could pull the head exchanger and add some more
