2001 Mountain Lite, almost done!
bravo-guy
Newfoundland
heres a couple pics of the sled, all thats left is to put in the MPI Transfer Enhancement Kit and change out the jets to go with the pipe and then its done :)
is that a 2" riser WITH a 1.5in pivot adapter? or just a 2 inch riser block? Nice lookin' machine. ;)! :letitsnow
Thanks guys and its just a 2" riser block with the bars tilted forward (I hammered off that rivet that limits the forward tilt on the bars)
progold said:
Nice sled good job,all you have to do is add a snow flap and that should complete the job,enjoy!!
haha about the snow flap, well it kinda got ripped off from being caught up in the track in reverse, so it got ripped off, and I dont need it for cooling, I might cut it down a bit so it doesn't get caught in the track and then bolt it on. I've tried out the sled and there is a good power/torque increase, sounds good to for a fanner. I can't wait for a real good run when I get the MPI transfer strap kit installed and the new jets put in, I had to order the jets :(
:letitsnow
The main jets are changed out now, all is left to do is install the MPI Transfer Enhancement Kit and change the slides, will I need to remove the suspension to do these things?
no skid removal
Pull the hyfax through a track window, remove the front screw first.
Transfer kit a be installed by removing the rear and middle mounts
Well I knew about the slides and the track windows but wasn't sure on the straps from MPI.
On a side note, the sled rips for a 500 fanner and acceration/torque had a pretty big improvement.
i put the straps on my 2001 mm700 and it works and transfers great, i did not take my track off to do it but it takes a bit of skill to cut off transfer rods!!!
