This was a project sled of my brother in law's and I did some trading for it. Part of the reason being he got so frustrated with it and moved on to another project.
Specs are it's an 87 SRV, bored .030, oil injection deleted, 38mm Miki roundslide with 370 main and 50 pilot, needle clip is bottom position, Boyeson dual stage reeds and DG pipe. Twist throttle and stripped down of a good 30lbs of weight it's gonna be a fun sled...if it ever runs right.
He's played with so many carb/jet combinations it's unreal. 38mm, 36mm rs...factory 44mm and 40mm butterfly, jetting up to 500 at one point on the mains and 30 on pilot...to the point where it's at now and just can't quite get it right.
What happens is it starts, idles ok, then the low/mid range is just flat, dead. It'll move pretty good to start on the snow, but you crack the throttle and it just has nothing there. Sputters a bit, and you really have to play with the throttle to let the engine pick up enough speed then KA-POW it's gone like a rocket. I was just messing with it yesterday and tried a couple of things...
Adjusted pilot down to 40, clip to middle, worse. Put back to other config. Drive it out of the shop, rolling along and slowly feed the throttle in, gets about 1/4-1/2 throttle and just bleh...nada, sputtering, keep feathering it a bit to pick up rpm/speed and BRAAAAAAP....hits that spot and runs out hard. Tried full throttle right out of the hole and it just falls on it's face.
Tried running a ground wire from motor to chassis, checked timing and it "looked" ok,(best I could see), new plugs, new wires, different coil....nothing has made a difference. I'm to the point now where I'm thinking of swapping in stock reeds but highly doubt that's it. Crank seals check out good, intake boot is brand new...oh and had Comet 108 on it, took that off and put stock clutch on, still no change.
CDI? Almost feels like an ignition/timing problem with the way it sputters but then at that one speed it does run hard and quick!
