wickedss
Venom seems to be running on one cylinder. Will stay running with the outside plug wires off and the center cylinder connected.
Will start off the outside cylinders but not the inside with a plug connected to the coil.
Has gas, oil, brand new plugs, carb boots are connected fine, etc..
Will idle but sounds very weak. Can run it on a track stand but its definitely not running right.
Any ideas?
Any ideas?
GibViper
Carbs clean??? Sounds like your pilots are plugged.
have you cleaned the carbs this season? good place to start.
does adding choke help???
Carbs say clean me!!!!!
