Lester
I have an o1 srx and I have no power going to the grip or thumb wamers,any ideas,thanks
If one of the warmers are bad, they will both be. Test them with a fluke on OHMS. One of mine read OL out of limits.
Concept Carbon
Check the wireing and conectors under the handle bar pad they like to run and ground out there.
rx1jim
Just as Concept has reccommended, check the wiring under the handle bar pad. Trace all the wires from the handle bar ends and thumb warmer to the connectors. Unplug and replug each connector. Over time the connectors can oxidize a bit causing a poor connection. Unplug and replug the connections. Look for broken wires and poor connections. If this does not solve the problem then you will need a multimeter to check each hand warmer and thum warmer to see if one or all of them have an open circuit. Post your results so we can continue to help you.
