carbs.?
PNPerformance
Callander, ON
For setting the float height at 13.3. Do the carbs have to be sitting flat or just when needle valve is touching the float to do proper adjustment.?
The float arm should be just touching the the top of the float needle...not compressing the spring...so you usually have to have the carb on a slight angle. [at least thats the way I have always done it]
Right on as usual....
