bufalobob said:viper w/ bender pipes:
gut air box
leave vent tubes in air box
needle - middle ( stock )
pilots - 60 accross
mains - 165 accross - mimimum - to 167.5
the air box not gutted is tooo restrictive. needs to be gutted for proper airflow to allow the pipes to make max power.
bob
Bob:
Would the restrictive nature of the Viper airbox[even gutted] not create too much negative pressure on the float bowls[causing a overly lean condition] for having the vent tubes "in the box"?
I'm thinking that, with that large of a main jets, the nozzles[needle jets] would have to be larger as well to flow enough fuel flow for what the main jet sizes require???
