2001 throttle and choke cable on 99
chilli
North Bay, ONTARIO, CANADA
I was wondering if anyone has swapped out the throttle and choke cables on their 98 or 99 srx for the ones from say a 2001, where they dont go through the airbox, but over to the side?
Can this even be done?
Seems as if a quick cable swap will make airbox work much friendlier.
Thoughts?
I changed to the longer cables on my 98 to help with the riser installed so yes it can be done and is no problem to do.I use the throttle and oil pump cables no need for the choke one as it doesn't go to the bars.
