the coolant bleed screw on a srx
383stroker
ontario
not sure where to find the coolant bleed screw on a 2000 srx. looked up in the tunnel on the rear heat exchanger can't seem to find it. not to sure what i'm looking for. a bolt or a tap?
Yeah Towards the back in the middle philips screwdriver...12 mill socket to get the seat off, unsnap the snaps and when you pull up on the front abit disconnect plug ..
