staggs65
that would do itbut I did notice the lower section is un-glued and is flapping open on that cylinder.
kinda leaving me hanging here staggs...
can you give me a percentage of certainty in your personal opinion?
is it possible the overheating caused it to fail?
staggs65
to make sure I understand what you were saying, are you saying the carb boot is coming apart and flapping open (thats how i took it) if so you are sucking alot of air on that cyl (therefore running way lean) that'll kill a piston in a hurry, certainly is possible for overheating to have done it too if I took that post wrong
good point I'll have to check those boots again.
The reeds themself are not sitting flat, theres a gap ( opening ) in the front ( opposite side from the screws ) maybe .010-.015" between them and the holder, is this just normal wear and tear and can it be fixed by just changing the reeds or do I have to change the whole assembly?
staggs65
should just need new petals
staggs65 said:should just need new petals
Stick with OEM reeds if you do replace them...
