You should always clean the carbs at the beginning of the season, doesn't do much good to do them at the end. They get "dirty" from the fuel sitting in them over the summer and then evaporating, leaving crud behind that then flows into your circuits when you fire it up again the next year. That's why it takes so many pulls to get them to fire up after sitting all summer, have to pull until it re-fills the bowls. Then the gas collects up all the crud from the evaporated fuel and carries it along through the circuits. A lot of people get away with it, it manages to pass all the crud, but also read every year about burn downs from this. Usually the first warning sign is it won't idle without the choke on halfway.
Your problem right now sounds like the TORS is activating. Since the carbs were cleaned at the end of last season, whoever put it all back in probably got the throttle cable too tight. Give the throttle cable a little more slack where it attaches at the carb rack, and give it a try again. Good luck, hope this fixes it for you.
