99669viper
Need some advice as to what caused the center piston failure on my STOCK 2003 SXViper Mountain with less than 1900 miles on it.
Thats where 90% ot the burns will happen(mid range cruse,on the needles),that temp is cold(runs leaner) but the other two holes look rich?? how did your plugs look when inspected? any air leaks in that cyl?99669viper said:Was easy trail riding in 25 degree temps
you didn't answer these ?s yet, which are very important???) are you jetted right for your temp and alt.?? runing good fuel with clean carbs??
Netefrog said:I'd would drain that coolant before you do anything else....
99669viper said:Well I fixed my Viper engine problem and bought an Apex that I will be picking up on the 26th. Thanks to all of you that responded.
modsrx said:good way to fix problem lollll![]()
