jwiedmayer
Anybody have any ideas what would cause all the oil to drain from my tank? I did have the gas tank out and the oil tank was just sitting there. I figured the oil line down to the pump was leaking but I removed it and it was fine. The tank itself is also fine. J
on it's side,upright? more info,,what sled?jwiedmayer said:the oil tank was just sitting there.
jwiedmayer
Redhead 700. Sitting in the garage. Tank in normal position not mounted to the gas tank. J
Not sure then with out beeing able to look at it,clamps good any trail of oil you can follow back to the source? a starting point of where it happend?
it just leaked down onto the bulk head?
X2... No puddle on the floor?daman said:Not sure then with out beeing able to look at it,clamps good any trail of oil you can follow back to the source? a starting point of where it happend?
jwiedmayer
Yea its all over the floor. I pulled the engine and I'm going to replace all the lines. The only thing I could think of is maybe that the clamp on the main line let the tube slide off the fitting a little.
you couldnt find source? a starting point of where it happend?
