OK I cleaned the carbs they are spot less. When i start the sled it idles good but at 6000 ish rpms it starts backfiring through the carbs. All three carbs back fire. It get worse as I rev higher. Any one have a clue? Ive changed gas pwer valves are set. Compression is 140 cross the board. TORs is disconnected temporarily... I'm lost.... I checked the wiring harness with no problems there......Don't know what to check now.
