SCIII Suspension
goingmach_1
Ottawa Canada
I have installed a SCIII suspension into my '98 SRX. The back holes are located at about the same height as the orginal. However after hitting a few big bumps the studs have contacted the rear heat exchanger.
Looks like I need to drop down the rear bolts to stop this condition. I did a search on this forum and found these drop brackets, but can someone tell me how they go on? Two, will they do the job I need done?
The main bolt hole in the middle would be where your rear suspension hole is now. Then they give you a template for four 3/16" hole to drill into it. Or you can do your own pattern also. Just put them on my Viper.
Did they work the way you wanted them too?
