I have installed a SCIII suspension into my '98 SRX. The back holes are located at about the same height as the orginal. However after hitting a few big bumps the studs have contacted the rear heat exchanger.
Looks like I need to drop down the rear bolts to stop this condition. I did a search on this forum and found these drop brackets, but can someone tell me how they go on? Two, will they do the job I need done?
bluewho
You dont have protectors?
Yamasquaw
- Jan 8, 2005
The main bolt hole in the middle would be where your rear suspension hole is now. Then they give you a template for four 3/16" hole to drill into it. Or you can do your own pattern also. Just put them on my Viper.
Nope, no protectors.
How would put one on the rear?
bluewho said:You dont have protectors?
Did they work the way you wanted them too?
Yamasquaw said:The main bolt hole in the middle would be where your rear suspension hole is now. Then they give you a template for four 3/16" hole to drill into it. Or you can do your own pattern also. Just put them on my Viper.
staggs65
they make protectors specific for the rear, they rivot in
