VMax riser???
oddfire
Ellensburg WA
How long of a riser can I run with out needing longer cables? Also, if I need new cables, do you have any ideas?
Thank you ;)!
mostsleds can put a 2" riser on their sleds without extending cables...some have been able to fit a 3" riser all depends how you reroute your cables....i personally have a 6" riser block and pivot adaptor so close to about 8" total...i bought the powermadd riser block pivot adaptor and the power madd extension throttle cables and it works great!! money well spent.
You could put the powermadd pivot 3.25 riser on. I put it on my srx700 with no problems. The cables had more slack than my 2inch riser because the pivot kit throws the bars forward.
I put a Rox 3.5" Pivot Riser on my SRX and my stock cables were plenty long enough.
