1000 ft. drag clutch setup
tjsands12
West Bend, WI
ive have a 2002 viper and am doing a radar run and would like to setup my clutch to be competitive. what would be the best setup for a 1000 foot drag on a lake. i have the heelclicker clutch kit. i am basically stock right now, except for the bender 4x4 pipe.
i can tell you that the clutchers are going to want a lot more detail on what you got, how it's setup, and what your rpms now from start to full speed, every detail: which hcs how they're loaded, primary spring, secondary spring, wrap, helix, gears and so on, unless you bought the sled new don't assume everythings stock still
well i know it was bone stock when i bought it and all i put on was the pipe and my cousin tweaked the clutch with what comes in the heelclicker kit. it engages at about 4200 rpm and tops out and about 8700 rpm right now. gears, helix, jets are all stock.
