drfbuster
- Oct 27, 2003
Merry Christmas everyone! I need the spring settings for the primary and secondary springs for an 02 Viper. These springs are off of an 03 Viper but i believe they are the same. Thanks! drf
mopar1rules
stock primary spring is y/w/y--45/128kg--2.5kg/mm rate
stock secondary spring is red @ 70 deg (hole 6 helix and 1 clutch), using a 47deg straight helix (#8bv71).
drfbuster
- Oct 27, 2003
Thanks mopar. one more question. does the 70 degrees refer to twist of the helix before bolting on the primary alsi how much twist for the secondary?drf
yamakazie
There is no twist in the primary. It's a compression spring only. the 70 deg refers to the secondary spring twist when you turn the helix clockwise to the studs.
staggs65
on secondary add the sheave hole number to the helix hole number x10=degrees wrap
ardviper
What will happen if you change the degrees of twist on the secondary spring???
Ride.Race.Live
dont want to hyjack but i got a question regarding secondary springs as well...
how do you read the "tention" on a set up?
