Mag side should be richer on a 98-99. ur plenty rich stock is 146-148.
yes clutch is pto
yes clutch is pto
staggs65
that jetting is the base jetting recommended with the cold air kit, but those recommendations were set up before our gas went to crap. i'd find a used shelf with the 3 holes and put it back in
Shafner79
staggs65 said:that jetting is the base jetting recommended with the cold air kit, but those recommendations were set up before our gas went to crap. i'd find a used shelf with the 3 holes and put it back in
You mean for the airbox? So get rid of the Cold air kit, or keep it and just get a stock top "shelf" without the extra cut-out slots on top?
Yes...centralPAvmax600 said:You mean for the airbox?
staggs65
theres anothe shelf that is supposed to be in the airbox under the top shelf go to portyamaha.com look on the microfische you'll see it
Shafner79
staggs65 said:theres anothe shelf that is supposed to be in the airbox under the top shelf go to portyamaha.com look on the microfische you'll see it
My airbox has everything but the 2 dividers.
On another note, I checked my pilot jets and they are all 42.5. I did notice the one on my mag cylinder (which had the burndown) had some corrosion on it? Kinda like copper pipe gets?? I cleaned it but it's kinda stained on the outside.
staggs65
oh, okMy airbox has everything but the 2 dividers.
