Check Out My Plugs
Concept Carbon
Ottawa, ON.
Here is a picture of my plugs they where brand new took it for a 1hr ride last 15 min of ride was a couple wide open pulls.
jets are 158.8 across
mag side on the left
Looks to me that your spot on..... BUT no room for error if your riding at night and temps drop, i see the center electrode is silver all the way across and your ground strap is burnt more then half way back.
hard to read new plugs,good to see your running ECS's,hows mid cruse look?, i would richen it up a tad $.02
stock sled? whats temps and alt??
temp was about -8f or -23c elivation 70-90m
its a viper with srx pipes megapower heads and mrviper porting.
Havent check mid cruise. Im runing 42.5pilots.
Thinking I may bump up to 160s
yes you are....try a plug check on each circut,low,mid and post them up. Are them the temps you guy's usally see up there??
what set up did you have before when you were ritch??
Il do a couple circuits, set up was the same besides porting. it ussually fluctuates temp quite a bit tommorrow its supposed to be 1deg. Average is below -10c
