extremeviper
I am consistantly blowing my head gasket in my 780 big bore hauck viper with venum heads. Any one else have problems with the venum heads?
mopar1rules said:if getting coolant to leak out the weep hole by water pump, i would check the little washer w/the rubber coating, to see if the rubber is junk. also, put some green loctite on the splines of the water pump impeller. chance of leaking there also, if splines are getting sloppy. also, check the domes on your heads....take the little 1" diameter o-ring off, where it seals by the spark plug...put dome into head shell, and measure the distance that the dome's gasket mating surface, sticks out past the head shells gasket mating surface. it should be like .001"-.002" for a good seal. that's how i've setup megapower heads, and never had a leak issue. should be the same for your venom heads. so, right now you don't know exactly where the leak is on the heads? and/or, which head?
extremeviper said:I took apart the water pump impeller/seals and ordered new. I just replaced the head gasket and noticed the increase in pressure in the cooling system because I routed the overflow pipe out the footwell. My thoughts are the waterpump was drawing air and loosing coolant and that caused the sled to overheat/blowing a head gasket.
extremeviper said:I'm headed to the machine shop in the a.m. to get the heads done. The domes are recessed into the head by .001 thanks for all the advice
maxwell said:What machine shop did you take them to? I have had luck with Cotreal racing in shakopee in the past.
