john7459
should i be able to see the coolant flowing in and around those little hoses running all over the carbs? I have the dial turned to on (on that thing that looks like a fuel rail). They all seem empty? I thought they were to heat the carbs, does it bring much of a performance gain?
No performance gain with them ON, they are for very very cold days, altought I don't think many of us use them. In my case I never turn them on. You won't see the coolant around those clear hoses.
ottawaair
coolant flows thtough black hose & carb bodies. The claer hoses are fuel & vent hoses.
Shafner79
Nicko said:No performance gain with them ON, they are for very very cold days, altought I don't think many of us use them. In my case I never turn them on. You won't see the coolant around those clear hoses.
I can't get mine to turn off....switch won't move!
all correct info up top,,very cold windy days OR if your busting alot of powder.leave off otherwise.
@centralPAvmax600,
you may need to use plyers to help turn yours,it'll move..
@centralPAvmax600,
ryanryan
daman said:all correct info up top,,very cold windy days OR if your busting alot of powder.leave off otherwise.
@centralPAvmax600,
x2....I leave mine on though...
I've found if you turn it back and forth on/off a frew times a season when ever you have the hood open it helps it from sticking.
