SNOWMOMAN03
hi , what oil works best in chain case is ther more than one weight oil you can use !!!
Just like engine oil you'll get a million suggestions on what people use, anything from motor oil to ATF and all in between, Yamaha calls for a 75 or 80w gear lube, i only run a full synthetic(Amsoil sever gear) 75w90 gear oil,and being a syn it's thin with a low temp pour point to help prevent rolling drag.
i recommend a synthetic gear lube.
I use syn, Amsoil ATF last year no problem,using again this time around.
YAMMIEGOD3:16
I USE AMSOIL. 3:16 (yammie tony)
SNOWMOMAN03
thanks for the reply !!!!!!!!
i think i will try some amsoil gear lube , i have allways ran amsoil 2 stoke oil its all good stuff !!!!
Amsoil Synthetic gear lube.
Danger Dog
ATF. I use it in my trail sleds and also my prostock without problems. Less expensive then synthetics.
mulderdad
amsoil synthetic for me too!
mopar1rules
i personally use amsoil 80w-90 synthetic gear lube. love the stuff. been using it for 3yrs now.
780srxgeorge
oil
i use 4 oz atf & 4 oz of motor honey sweet mix been useing for 5 yrs
ryanryan
I got some Shell Snowmobile Chaincase Oil this year when I changed my track. It's all personal preference, just stick to a well known brand of either gear oil, chaincase oil, or maybe ATF/Engine oil.
Why you would want to use MH is unclear?,all it is a oil thickener(viscosity improver,not good thing in cold) with no additives,you aint got much protecting your gears/chain in there.780srxgeorge said:i use 4 oz atf & 4 oz of motor honey sweet mix been useing for 5 yrs![]()
780srxgeorge
i use ATF also ! 4ozs .the MH is daluted & sticks to every thing thats wher the ATF comes in.never had problem! even in the COLD
Nothing wrong with ATF... but the MH is not needed ATF will "stick" just fine by it's self. go try and pour MH out side in 10 deg temps would you want that tar in your case? it does nothing for it but prevent the atf from getting by the seal lip and into the bearing because it's so thick. but to each is his own carry on men.
took chaincase apart tonight to change upper tooth sprocket.Put it all back and used ATF again.
Add any motor honey doug?bluemonster1 said:took chaincase apart tonight to change upper tooth sprocket.Put it all back and used ATF again.
rx1jim
I also reccommend opening the chaincase and cleaning out the accumulation of metal particle sludge at the bottom of the chaincase. Changing the oil through the drain hole is not good enough. I also change the chaincase oil every 800 - 100 miles, it uses such a small amount and is inexpensive. A clean chaincase is a happy chaincase which will not leave you stranded.
unchained
A T F
whats ATF??? (all the farce).......What's all the farce????? lol
daman..you know what works really well..I add a teaspoon of Maple Syrup .It really gets everything nice and sticky...everything sticks to everything..it's on the garage floor...on my friggin boots....tracked it into the house...wife saw what I did..
and then the fight started.....
PS:you should try it sometimes....you'll be amazed where and what it'll stick to..lolll
