Bender Reaction owners manual NEED
zrx00
mn
Looking for any info on setting up a bender reaction rear suspension. I just bought the sled. Looking for a owners manual or set up info Or??? Please Help!
Lund9995@comcast.net
THANKS in advance! Tim
I have one in my srx. It came with the sled and i too do not have a manual. Spent lots of time adjusting and it works great now, lots of transfer and a great ride. I can probably help you adjust it just let me know whats wrong with it.
It seems really too soft. Also I dont know how to adjust the rod on the bottom and what does it do? And where are the dampning adjustments? What kind of sag am I looking for?
Thanks Tim
You need to crank up the spring preload a bit and the compression adjuster should be on the front end of the shock just below the spring. It is a red aluminum dial, it has 40 clicks of adjustment, I think turning clockwise makes it stiffer, but you will have to turn it all the way to really notice. I got mine re- valved stiffer and it is set half way and is still very plush. The control rod affects the weight transfer, turn CCW to increase transfer, CW to decrease. Also my front limiter strap is pulled all the way in, still lifts the skis on hard acceleration. This skid is really plush and they are not set up for bigger guys. I hope this helps.
