srx to sx-r tunnel/bulkhead
snocrosser
Avoca, Mi
Anyone know if there is any difference in the tunnel and bulkhead on a 2000 srx to sx-r, or would a sx-r motor bolt into a srx chassis?
You might be able to learn if this swap is possible by comparing the part nos from the parts catalog for each sled.
Different
The front aluminum cast sections of the buld head are different so the front motor mounts wouldn't line up. You would need to change this piece along with the front heat exchanger then it should drop right in.
Madmatt
