motofishsled
I have this crazy electrical problem . When i put on the brakes ( sled not moving ) it makes sparking and grinding under the flywheel .
I have replaced every wire for the back lights , brake lights , light socket , brake light switch , removed the stator and tested with ohm meter (perfect ) . When i unplug the brake light switch it has no noise or sparking . The engine runs perfect always this does not effect it . At night you can actually see sparks coming out of flywheel . ANY IDEAS ? RECTIFIER ? VOLTAGE REGULATOR ?
