how do I bleed oil injection 02 viper
Z06 FAN
Ontario
I was just doing a bunch of work to my 02 viper and need to bleed the oil injection. Can someone please advise me on how to bleed the system.
There is a phillips screw between the clutch side carb and center carb, All you need to do is unscrew this and let all the air outta it, and replace screw!
Bleed bolt is here ,fill bottle let her flow till no air bubbles is seen,as far as the oil lines(going to/feeding the fuel pump) you could start it up pull up on the oil cable to put it in full flow that will bleed the air out in a hurry,,have little pre mix in the tank till it's bleed out.
