Bender 4x4 pipe=500rpms??
stein700sx
Southern Manitoba Canada
Did lots of work on the 02 Viper. Included in all my work is a bender 4x4 pipe and torque limiter. Went out for its maiden voyage today and I seemed to have gained about 500rpm over last year.Couldn't do to much testing due to lack of good snow or straight flat trails. On the few pulls I could get the engagement is good but it hits 9k and stays there. I didn't think that I would have this much gain in rpm with two extra mods. Belt is sitting about 1/16 above the secondary.
This is how its set up right now;
Primary-Grey spring
HC's with heel 2.3 mid 3.3 and tip3.3
Secondary-Red spring wound at 70
48/36 dalton helix
Ported by mrviper700 ;)!
Stock gearing. stock jetting.
Just for fun, I will put on the stock pipe this weekend and see if it drops the rpms.
From what ive read, this is normal. Increasing horsepower w/ out re-clutching will increase rpm.
even pipes and jetting is quite a power gain and would throw off your clutches and pull more rpm. mabye try throwing a little more weight at the primary that will bring it down. 9000 is out of your peak power 8350 is where you want to bee for stock, some go a little higher that have alot of mods but only by maybee 200 rpm.
When i put my bender 4x4 on my 03 mtn it gained about 400rpm. It sits right at 9000, long pulls on hardpack it will hit about 9100.
You also may overshift by backing off the secondary wrap= not good.
Someone else asked above, did it gain rpm's from just the pipe, or from porting too? If it's just the pipe, that's a pretty good gain. Is that with the stock can?
Gains were after the pipe and torque limiter were installed. Stock silencer.
Gotto find me a clutch alignment and check to c-c and offset. If thats all good then I will go into the primary.
Was reading in some threads about HC tuning. One thread mentioned that with HC's one should not put weight in the mid.Mine right now has 2.3 heel 3.3 mid and 3.3 tip. Should I put a little more into the heel move the mid and load up the tip to control the over rev or just leave the heel and mid as is and just go after the tip? My engagment rpms are fine.
