I've been trying to get my grips to heat on my 02 Viper ER so my hands don't freeze anymore.
Last year I installed 07 Apex bars hoping for more heat (and I like the built in hooks,alot!). I even isolated them from the bars with shrink tubing.No better than the stock grips. I also cleaned the flywheel,changed the stator,CDI, variable resistors and even the battery. Nothing helped.
So today I was doing some testing with 06 ,07 Apex and the orignal 02 Viper
grips.
This is what I found.Running the sled just under 4k rpm I get 13v at the grips.
The 07 and 02 grips get semi warm after about 2 minutes but don't get hot.
the 06 grips get very warm in about 1 minute.If I run the 06 grips in paralell they get hot in about 30 secs. So the question is will I do damage to the CDI or stator running them like that? Or should I keep them in series staying closer to the stock resistence of the Viper grips? Stock Viper grips are wired in series.
Grip Specs in ohms
Series Paralell Single
02 Viper 3500 900 1700
06 Apex 4400 1200 2200
07 Apex 13800 3400 6800
I don't have an amp clamp to check the draw in amps.
Testing all the combo's (directly on a battery) in series and paralell the 06 grips where by far the quickest to heat up and the hottest.
Just a side note. When the brakes are applied, the volts drop to 5. Found that a little strange.
grips.
Grip Specs in ohms
