how much smaller in diameter is a 8t driver than a 9t ?
I never measured the difference when I changed over to the 8 tooth drivers, but I remember that with my original 9 tooth and an 1 1/2 inch track I had a tight 1/2 inch clearance between my lug and the front cooler. When I went to 8 tooth and put a 2 inch on, I had the same clearance. So I would guess the difference would be a 1 inch diameter difference.blk04700 said:how much smaller in diameter is a 8t driver than a 9t ?
excellent ,thanks that exactly what i was needing to know. now i just gotta find some 8t drivers.....
I seen a set for sale yesterday either on here or snowest. Guy was willing to sell them on or off the shaft. Good luckblk04700 said:excellent ,thanks that exactly what i was needing to know. now i just gotta find some 8t drivers.....
just thought id post up the actual size diffrence, 8t kimpex drivers are .770" smaller than the stock 9t drivers , for an increase of only .385" between the tunnel and the track. should let me get the track in but studs will be out of the question unless i do another driver change.
