driver question
blk04700 said:
how much smaller in diameter is a 8t driver than a 9t ?
I never measured the difference when I changed over to the 8 tooth drivers, but I remember that with my original 9 tooth and an 1 1/2 inch track I had a tight 1/2 inch clearance between my lug and the front cooler. When I went to 8 tooth and put a 2 inch on, I had the same clearance. So I would guess the difference would be a 1 inch diameter difference.
excellent ,thanks that exactly what i was needing to know. now i just gotta find some 8t drivers.....
I seen a set for sale yesterday either on here or snowest. Guy was willing to sell them on or off the shaft. Good luck
just thought id post up the actual size diffrence, 8t kimpex drivers are .770" smaller than the stock 9t drivers , for an increase of only .385" between the tunnel and the track. should let me get the track in but studs will be out of the question unless i do another driver change.
