badboy81
cleaned my carbs,put it back together ran fine,cleaned my power valves,now it wont idle right.i know the valves are adjusted right cuz i stuck my hand up the cylinder and the valve is flush with the head with the servo in the open position.i think its only running on the 2 outside cylinders.all 3 get hot but the middle one,if you put your hand over the carb it still runs.if you do it to the other 2 carbs it kills the engine.also if you spray staring fluid in the outer 2 the engine revs up,if you spray it in the center one it bogs out.all 3 have good spark and good plugs.any ideas what it could be?thanks
its nothing you did with the pv's,pull carbs check er out,check reeds,make sure all carb slides are moving up/down,,
1 spark
2 compression
3fuel
should run..
1 spark
2 compression
3fuel
should run..
badboy81
ya took the carbs off again everything looked fine,all had gas in themchecked the reeds those were good too.gona do a compression test tomorrow...
.......daman said:make sure all carb slides are moving up/down,,
no1chevyboy
check choke on center carb
