mod man..I am sending this stone out to your area so that you can pick it up on your skid next time you are riding.Don`t blame me if you can`t see what you hit or ride into..lollll Better have a telescope mounted on the handlebars and look ahead for it.I will even paint it Blue for you..lmao!!!!
taylzee
We put a MM700 into a river bank a few days ago. It looked real bad but upon inspection...Twisted spindle...nothing else. The ski was bent up inside the steering arm inside the nose pan. All steering arms are good. We changed the spindle out and the thing is still straight as an arrow. I found it very hard to believe you can twist 1/4 hardened steel and not even take out a trailing arn or steering arm. Sometimes you get lucky and others you don't! Glad to here it was minor!
yeah me to....am glad..thanks
kirk700 srx
I put my Viper in a bog hole one -30C night I was stuck up to my nuts in water. I flipped the sled over and over again to roll it outta the bog hole not realizing that water freezes fast at -30C. I was out and in the clear and all I needed to do was start up the sled and drive away . I Pressed the throttle as I pullled the sled over and the throttle stuck wide open sinking the sled into another hole .The sled spit 3 baseball sized rocks up into the tunnel and jammed solid. Never had reverse so that wasn't an option to try and spit the rocks out the opposite way. That was one cold walk home I tell you what!
