I have no spark and i checked the carb switch so far, it was running just fine turned it off and havent had spark since. I am just wondering where i would go from here? Can i bypass the ignition(easy), or how would i check it for proper operation. Please help me have a trip coming this weekend!!!
TJ500
1) make sure ignition switch AND engine kill swiches are in the ON/RUN positions..
2) open Black/White wire from both above switches..
3) check for spark..
if you have spark:
4) close Black/White wire for each switch, ONE AT A TIME, checking for spark after each closure..
step 4 will help determine which switch is defective, if indeed one of these are the problem..
the Black/White wire from each of these sends the switched ground to the CDI to kill the engine... tj
if you have spark:
Thanks I'll give it a try, also you wouldnt have the resistance spects for the stator on this sled would you, if so could you give me the ohms for each wire. thanks for your help!!
TJ500
sx700r2 said:Thanks I'll give it a try, also you wouldnt have the resistance spects for the stator on this sled would you, if so could you give me the ohms for each wire. thanks for your help!!
I do have a manual somewhere but haven't (for 2 seasons) been able to find it?.... Perhaps someone else can post those for you...
I do think Daman has many applicable genuine Yamaha manuals.... tj
Thanks alot for the info!!!
