sx5oor no spark
sx700r2
michigan
I have no spark and i checked the carb switch so far, it was running just fine turned it off and havent had spark since. I am just wondering where i would go from here? Can i bypass the ignition(easy), or how would i check it for proper operation. Please help me have a trip coming this weekend!!!
1) make sure ignition switch AND engine kill swiches are in the ON/RUN positions..
2) open Black/White wire from both above switches..
3) check for spark..
if you have spark:
4) close Black/White wire for each switch, ONE AT A TIME, checking for spark after each closure..
step 4 will help determine which switch is defective, if indeed one of these are the problem..
the Black/White wire from each of these sends the switched ground to the CDI to kill the engine... tj
Thanks I'll give it a try, also you wouldnt have the resistance spects for the stator on this sled would you, if so could you give me the ohms for each wire. thanks for your help!!
I do have a manual somewhere but haven't (for 2 seasons) been able to find it?.... Perhaps someone else can post those for you...
I do think Daman has many applicable genuine Yamaha manuals.... tj
