bim lights on 500xtc
09nytro
Grayling,Michigan
The lights are real bim and it gets bimmer when it warms up does any one know what wires to ohm and what values are . Unplug volt/reg didnt do any thing . checked charging system at batt its @ 13.89 when i rev it up . :o|
I hear that crud can build up in the stator cover and reduce the light output. Try taking that off, then use a shop vac and a blow gun to clean it out if there is anything there. Otherwise, I guess rust can develop there and make the lights go dim.
I think this might be partly why my passenger grips on the venture don't heat well. I will head up north soon to try that.
I just put main seals in it (has about 8950 miles on it though it would be a good idea) just checked reg/rec @ blue wire nothing @ white wire nothing @ red wire @ idle 12.35 thinking its the reg/rec maybe it has voltage reg to . How do you test that :o|
