Cleaned my power valves on my 01 srx. Not to bad being 1700 miles and yamalube. Purchased maxx's pv tester. What a pain to get hooked up. The electrical ends were a bit to big for the female end on the sled. The directions were fine but that kind of ticked me off. Activated the motor, didn't really move to far ?? Checked gap at the cable/valve connection , all were around .16"(spec .08 -.14) Adjusted all three to .11 .
Questions:
Is the adjustment distance somewhat typical?
How far should the motor actually turn? ( I did pull on a cable a bit and she did return a few times, looked to be only around a half inch)
This may help others:
Used two drill bits (the size of the gap I wanted) and slid them in at bothsides of the flanges to get a good measurement on the gap. It helps get the mating surfaces squared up with each other.
Try to fit those male ends on the tester in your female plug before you put them in the plug cover. If they don't fit they'll just push out the end of the plug and piss you off.
Questions:
