donkeypunch
Looks like it's running pretty rich.
As for the lights dimming when I bring it up to 1600-2000 rpms the lights are fine. But I can grab the brakes and make them dim at higher rpms....
Check the H/L bulb
Make sure you have a 60/55w bulb not a 100/55w
donkeypunch said:As for the lights dimming when I bring it up to 1600-2000 rpms the lights are fine. But I can grab the brakes and make them dim at higher rpms....
braindead1684
X2 my dads sled had the higher wattage bulb and it did that. If you have the correct bulb and stillhave problem with the dimming at higher rpms with the brakes on I would suspect a possible voltage regulator or stator issue.
