SNOWMOMAN03
hi , is there a easy way to synchronize the carbs on a srx 700 , do i need a sync tool like u use on a 4 stroke ?
the Wolfman said:Easy way to sync carbs is with a drill bit .. carb rack removed.. use a 1/4 ( or similar size) and turn up the idle knob until the bit slides under the slide in the master carb... adjust slaves until the same thing happens to each.. verify by opening throttle cam to check all slides reach top of bore at same time, return to idle.. recheck... remember to back idle knob off and then re ajust with sled running..hope this helps
