Driveshaft bearing size 84 phazer
stinger440
GR MI
I think this is the last wear part left on this machine. Anyway what size is the driveshaft bearing on the speedometer side? I have the OEM number but I would like to get the actual size or industry # 620... etc. Thanks in advance.
bearing
Are you asking for jackshaft bearing behind secondary clutch that goes into aluminum holder and held in place with cam lock/set screw? If so it is 25mm id bearing. The shaft od is 25mm (not 1"), the aftermarket bearing number is CSA205-25. Send me pm and I get get phone number to order. They are around $7.50 each compared to Yammy at around $70.
Acutally I am looking for the bearing on the track drive shaft behind the speedometer drive. Looks like 6022 2RS is the magic number so far.
Damn that would have been nice to know. I just replaced it.
And of course I damaged it trying to press / pound it in to the (also brand new) aluminum holder. I don't know why this needs to be a press fit, but it is.
Hopefully it holds up. I screwed up the seal on the bearing a bit, so I gooped grease around it to hopefully keep dirt out.
I am going to keep that jackshaft bearing number in my back pocket because I am sure that will be next.
Found the bearing 60/22 2RS Thanks for the help guys.
