Viper oil pump setting
Sameyeam
Appleton
Just wondering if it would be better for my machine if the oil pump was set a bit richer and possibly aid in preventing another burndown? i know there is a cable adjustment but there is also a phillips drive screw that bolts to the reed block which seems to be an adjustment. What is this? Does that richen up the oil mix a bit?
I believe the bolt /screw you are referring to under the carbs/reeds is the "bleed bolt" for bleeding oil delivery line, it is not an adjustment point.
Manual says to make adjustment at Cable. Distance = 0.866 + - 0.039 in.
That is a bleed screw you use when you put on a new pump or run it out of oil. It is not an adjustment screw. Only adjustment is in the cable.
Where are you now??
how much oil to gas are you useing???
you check it pulling the cable halves appart here and here
we need your gap "a"
alright ill take a measurment asap, it was using about a quart to 5 gallons i would guess....didnt take a super accurate measurment but thats about what it is
again....that was a stupid guess, it didnt foul plugs or smoke too much so im thinking its set right
So thats telling us it's set right?, Ok...if you want it right post back with that info.
good luck...
