96 Vmax 600 XT Fuel Capacity
mooserini
Niles, MI
Hey, I've looked all over and my sled didn't come with an owners manual.. how many gallons does this thing hold... I ran on a fairly decent trip the other day and it was reading half tank so I topped off for the return ride home and it only took 3.2 gallons... are these only 7 gallon tanks?!
Thanks in advance for your help...
oh yeah.. and I've read this is common but I haven't read the solution... sled seems to bog unless to really open up the throttle.. I did everything in the GYTR installation guide that they suggested... WOT is great, just seems like up to half throttle it's kinda sluggish... I know I am getting fuel, oil and good spark.. I just put two new pistons and rings in it and checked the oiler and oiler alignment... Maybe I should drop my needles a bit to lean it some at the bottom end since I fattened up the main jets for the pipes @ WOT?
I'm more concerned with the answer to the fuel tank honestly.. I can figure out the other issue if I have to on my own, but why spin your wheels if someone else already has?
Thats not too bad...I went 60 miles and had to put in 19.3 liters (5.1 gallons) to fill it up when I got back. I should be able to get 120 miles per tank no problem. Thanks for the info.
