Any easy way to pull the cylinder off 78 SRX 440?
MichaelF3992
Central, CT
Looks like the studs are sticking in the cylinder through holes. Anybody have any tricks to pulling the cylinder off without breaking the ears at the bottom like I did with the 1st cyl? Special Puller?
ears
I believe he is talknig about the ears on the bottom of the cylinders that slide in the crank case. I could be wrong though.
PUT A SHOT OF WD-40 DOWN THE HOLES WHERE ITS HANGING UP AND LIKE THESE GUYS POSTED , TAP IT WITH A RUBBER MALLET. 3:16 (yammie tony)
jig-a-loo and rubber mallet.
Sometime light twisting with a piece of wood cut to barely fit down the cylinder (need to drop the piston to the bottom of the stroke) helps.
2 hours of tapping up and down with lots of Pb Blaster, one more to go. Sled sat for a long time outside, everything is seized up. You are correct with the ears I was speaking about, the part that slides into the crank case.
Thanks, for the advice.
