I'm convinced that no matter what supplier you get the jackshaft, drive axle, or bogie wheel bearings from, they all do not have the right grease in them for sled applications. The reason all of these bearings fair is from water getting in them, washing out the grease and the balls and races begin to rust and pit. The bearing fails quickly afetr that process starts. The seals on all of these bearings do let water get in, a small amount, but enough to start the problem. Not matter who I get bearings from, I remove the seals with a dental pick, clean out the original grease and repack them with a synthetic grease like Mobil 1 grease. Most of the bearings on my rear suspension are original, with 13,000 mile son them. Try this process, your bearings will last a lot longer.
