clutch spring question
sickric
central Wisconsin
02 , Viper, 3600,miles, stock all the way around. Engages at 3800, WOT is at 8800. Don't really have any problems & am happy with the way it runs, .......but................
Would i get any benefit from replacing my primary and secondary springs with New OEM springs? when do clutch parts typically start to wear out ? (mileage )
Reason I am asking, I am going to install new rings, and want to freshen anything up that may need it right away.
also, would I benefit from new stock reeds, do these wear out or only replace if they are broke, cracked ?
i would leave the springs alone, if your running those rpms. springs sound fine to me
you can check them if you want, to see if any were starting to chip on the tips. seems like the middle petal takes the biggest blunt of the damage.
